MonkeyManor
Apr 20, 2020Tutor
Orbi RBK852 is not reliable
I have recently purchased the RBK852 for my house and it has to be the worst purchase I have ever made regarding network equipment. Here are the reasons: I test my internet speed from the Orbi...
Apr 21, 2020Guru - Experienced User
MonkeyManor wrote:I have recently purchased the RBK852 for my house and it has to be the worst purchase I have ever made regarding network equipment.
- I test my internet speed from the Orbi app and get 200+Mbps, my devices get 6-30 Mbps. They used to get 100+.
- My devices lose connection while using them and I have to reboot.
- Anytime I turn off my TV or my PS4 I have to delete the wifi connection and reestablish it when I turn the device back on.
- My devices connect to the Router upstairs at 2.4 GHZ vs the Satellite until 3 ft way at 5 GHZ.
It's just not operating as advertised and for the amount of money paid it should function. The model number is not in the drop down.
My firmware is the latest at this time.
In addition, I was on hold for an hour and the CS rep hung up on me.
MonkeyManor
Apr 21, 2020Tutor
Hi,
the Modem is Arris, Surfboard, SB6183.
Home Area is 2,800 Sq Ft.
I followed the link for the setup of the device. One upstairs on East side of house, One Downstairs on West Side.
Channels are Auto. I will try the other channels.
There are two wifi's in the neighborhood.
- FURRYe38Apr 21, 2020Guru - Experienced User
Be sure to check the CTS and RTS values as well.
- MonkeyManorApr 21, 2020TutorI have made the change CTS/RTS. I am still having a problem with the devices having great bandwidth and then dropping. For example, this device has been at 100+Mbs and then it will drop down to <1Mbp.
What is the distance between the RBR and RBS?
If you turn OFF the RBS, do you still see the drop in speed with the RBR only?
