MonkeyManor
Apr 20, 2020Tutor
Orbi RBK852 is not reliable
I have recently purchased the RBK852 for my house and it has to be the worst purchase I have ever made regarding network equipment. Here are the reasons: I test my internet speed from the Orbi...
MonkeyManor
Apr 21, 2020Tutor
Hi,
the Modem is Arris, Surfboard, SB6183.
Home Area is 2,800 Sq Ft.
I followed the link for the setup of the device. One upstairs on East side of house, One Downstairs on West Side.
Channels are Auto. I will try the other channels.
There are two wifi's in the neighborhood.
Apr 21, 2020Guru - Experienced User
Be sure to check the CTS and RTS values as well.
- MonkeyManorApr 21, 2020TutorI have made the change CTS/RTS. I am still having a problem with the devices having great bandwidth and then dropping. For example, this device has been at 100+Mbs and then it will drop down to <1Mbp.
- FURRYe38Apr 21, 2020Guru - Experienced User
What is the distance between the RBR and RBS?
If you turn OFF the RBS, do you still see the drop in speed with the RBR only?
- MonkeyManorApr 22, 2020Tutor
One is upstairs and one is downstairs. I would guess about 50 ft in a straight line.
I have turned off the RBS and still have issue.
