rovers
Jan 17, 2020Aspirant
Orbi RBK852 NETGEAR Armor and Disney circle and internet
Anyone know when the Orbi RBK852 series will work with Netgear Armor and Disney Circle? Also have an interesting internet situation. I recieve internet via a wifi service. If I plug the inter...
Bandito
Jan 17, 2020Luminary
Boy, the situation with the switch is really a weird one! I can't imagine what the switch would be doing that's any different from the direct connection.
The only thing that I can think of is to try a different cable between the modem and the router. There are two types of cables, normal and direct connection. Direct connection cables, or crossover cables, allow you to connect directly between two network cards rather than going through a switch. Most network interfaces nowadays will work with either cable type, but some wii not automatically re-configure themselves. It's unlikely that you have a crossover cable, but it's worth checking, just in case.
