DarthSwede
Mar 28, 2025Aspirant
Orbi Rbk852 No Gig Internet 😢
I have Spectrum Gig with 40 mbps upload. I cannot get the Orbi system to hit more than 100mbps since upgrading. When I was on the Spectrum 300 plan, speeds were good. I just got a new modem from Spect...
- Apr 15, 2025
**Solved**. It was actually a bum CAT-8 cable between the modem & router 😭. Once I replaced that cable, I was back in business. Thank you for the reply!
CrimpOn
Mar 28, 2025Guru - Experienced User
100Mbps is a "special value". Does the Orbi report more than 100Mbps (even 101 or 102)? Or does it always report less than 100Mbps?
Would it be convenient to check the Orbi web interface, Advanced Home Page, and select "Show Statistics".
What speed is displayed for the WAN Port?
DarthSwede
Apr 15, 2025Aspirant
I didn't check the WAN port, but it was always less than 100
