Markedly
Apr 27, 2021Guide
Orbi RBK852 not showing attached devices
So, I've just installed an RBK852 pair, and the speeds are great: 300Mbs over wireless backhaul - that's the limit my ISP sets. However, I'm finding the web-based management lacking. My bigg...
- Apr 27, 2021
Ok, So you can try this out. Turn ON the RBS.
Try turning down the power output of the RBRs wifi radios from 100% to 50% or 25%. Apply the change then reboot the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
If your devices are still online, they should pick and choose to connect to the RBS. You can log into the RBS web page there to see whats connected to it. Though sometimes "unknown" maybe seen on the RBS web page. Known issue here.
Apr 27, 2021Guru - Experienced User
Can you provide a screen capture and select the Choose File to attach the picture file too on your next post?
What browser are you using?
Are these devices setup with Auto Obtain IP addressing in there networking configurations or using Static IP addressing by chance?
Have all devices been powered OFF, then power OFF the RBR for 30 seconds then back ON, then power ON the devices one at a time to see if they appear in the Connected Devices section on the RBRs web page?
