KOR-CAT
Oct 24, 2019Aspirant
Orbi RBK852 Power Adapter Voltage Label(Free Voltage?)
Orbi RBK852, Free Voltage? I am, Korean. Does the the Orbi Wifi Power Adapter (purchased in America), read 100V-240V on the label? Please advise! Thank you!
schumaku
Oct 24, 2019Guru - Experienced User
Hi,
I would suggest to strongly avoid buying an US/FCC version (Kit model RBK852-100NAS). While not checked the WiFi 6 Orbi, from experience we know that Netgear's FCC equipment can't be reconfigured for different wireless regulatory areas, the region selection does only allow U.S. (and probably Canada). You might want to look for a RBK852-100EUS or RBK852-100PAS (don't know if the later does already exist) - these are typically "worldwide" systems allowing the regulatory/country selection.
- KOR-CATOct 24, 2019AspirantRBK852, Free Voltage?? Yes or No?
RBK50(made in usa), It is used in Korea.
No problem.- schumakuOct 24, 2019Guru - Experienced User
KOR-CAT wrote:
RBK852, Free Voltage?? Yes or No?Assuming Netgear does ship the same 12V/3.5A power supplies like NETGEAR AC/DC POWER ADAPTER 12V 3.5A FOR 100V-240V AC 50/60HZ (PA7000P) as with many other products ... probably yes. And their factories can (and do sometime) supply other power supplies. I don't know as I'm not Netgear and have no insight on thier product delivery chain.
No problem.Made for the USA probably, unlikley made in USA. Problem ... as it is illegal and can't be changed to Korean region I'm afraid. Your risk - not mine. Not interested in reading later that your mobile or IoT or whatever don't connect, or the KCC (대한민국 방송통신위원회) does ring on your door.
- theBrick89Oct 25, 2019Star
absolutly true. it is illegal to use wireless communication device that aren't complied to Korean regulation standard in Korea. please avoid buying RBK852 until they update the firmware to support other regions.
and the US retail set comes with power supplies that are rated for 110-120v use only.
