KOR-CAT
Oct 24, 2019Aspirant
Orbi RBK852 Power Adapter Voltage Label(Free Voltage?)
Orbi RBK852, Free Voltage? I am, Korean. Does the the Orbi Wifi Power Adapter (purchased in America), read 100V-240V on the label? Please advise! Thank you!
Bandito
Oct 26, 2019Luminary
It is only rated for 100-120 VAC at 50/60 Hz
- KOR-CATOct 26, 2019Aspiranthttps://www.amazon.com/gp/aw/d/B07FCBDN1V/ref=ox_sc_act_image_1?smid=A2R1BZZDYXYHAK&psc=1
input : 100-240V 1.0A
output : 12V 3.5A.
product at the url address.
Support for specifications used in Korea.
Is it RBK852 compatible?- theBrick89Oct 26, 2019Star
Beside the size and build, most recent netgear orbi products shares the same power adapter specs.
I notice the new one is bigger and bulkier, though run way cooler than any other ac adapter I have.
if it uses the same plug for device end and have met the required power spec (12V, 3.5A output), it should work no matter what.
