rbgb42
Apr 03, 2023Aspirant
Orbi RBK852 router capped at 100Mbps
Hi My RBR850 router is capping at 100Mbps. Router is connected directly to ONT fibre. Cable tested fine. ISP test also confirmed speed at over 940Mbps. This is a 1Gbps line. Router has latest...
CrimpOn
Apr 03, 2023Guru - Experienced User
I agree with plemans . A speed of "just a bit under 100Mbps" is a clear signal that the ONT and router have auto negotiated a speed of 100Mbps Full Dupex. https://en.wikipedia.org/wiki/Autonegotiation and this will be verified on the Orbi web interface, Advanced Tab home page by clicking on the blue box Show Statistics. This is a feature built into modern Ethernet chipsets and happens automatically (hence the name).
Although the cable is the most obvious culprit, it also might be the case that one of those tiny gold wires in the RJ45 jack is slightly bent and not making good contact. I have also had cables where the RJ45 plug on the cable did not "click" correctly in the Orbi jack.
rbgb42
Thank you for your responses and pointing me in the right direction.
Much appreciated
