Dwayne011
May 20, 2021Aspirant
Orbi RBK852 Speed capped at 100mbps - Hyperoptic (UK)
Hello, I have recently purchased teh Orbi RBK852 and I am having issues getting speeds above 100mbps. My ISP is Hyperoptic and I have the 1gb service. My previous router was an TP Link AX50 ...
CrimpOn
May 20, 2021Guru - Experienced User
Dwayne011 wrote:I have recently purchased the Orbi RBK852 and I am having issues getting speeds above 100mbps.
The modem and router are supposed to autonegotiate the ethernet link between them. Can you check the Orbi web interface, Advanced Tab, click the blue box Show Statistics and verify that the Orbi thinks the WAN link is 1000M/Full? Sometimes a cable or jack issue causes autonegotiation to fail and the link sets up at 100M/Full.
- Dwayne011May 26, 2021Aspirant
Its definetly this issue.
I have tried load of different cables still the same result.
Is there a way to set it manually?
- FURRYe38May 26, 2021Guru - Experienced User
No, it's automatic. I'd try a different modem/ONT or possible that the RBR could be fautly. Would have to check with a different ISP modem or ONT. Do you have a friend for family member or a nieghbor near by were you can take the RBR to and connect it to there modem/ONT. See if the rate changes, if it does, then you'll know the RBR is faulty and needs to be replaced.
