Dwayne011
May 20, 2021Aspirant
Orbi RBK852 Speed capped at 100mbps - Hyperoptic (UK)
Hello, I have recently purchased teh Orbi RBK852 and I am having issues getting speeds above 100mbps. My ISP is Hyperoptic and I have the 1gb service. My previous router was an TP Link AX50 ...
May 21, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
https://www.reddit.com/r/orbi/comments/nh49sj/orbi_rbk852_speed_capped_at_100mbps_hyperoptic_uk/
Thank you.
Dwayne011 wrote:Hello,
My ISP is Hyperoptic and I have the 1gb service. My previous router was an TP Link AX50 and this had no issues geeting speeds higher than 100mbps.
Can anyone help?
I am based in the UK by the way if that makes any difference.
