eec801
Oct 27, 2023Aspirant
Orbi RBK852 unstable speeds
I've had my RBK852 setup for ~18 months running wifi from a google fiber router with 1 gig service. Speeds have been solid throughout the house with a ping of <5 ms and typical upload / download of 4...
Oct 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is or has Armor or Smart Parental Controls been enabled at all?
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
What PING results do you see with a wired PC and Ooklas installable speed test app?
- eec801Oct 27, 2023AspirantRe: Orbi RBK852 unstable speeds
What Firmware version is currently loaded? Currently on V4.6.14.3
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? GFLT132
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. Yes, and replaced as part of testing.Is or has Armor or Smart Parental Controls been enabled at all? No
All has been normal until earlier this week. Have done multiple reboots following the steps outlined above and comes back with same 'lower' and 'unstable' speed each time. When wired to fiber modem, ping is 1 ms and speeds are >1 gig up and down.
- FURRYe38Oct 27, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP ONT and router been performed?
What PING results do you see with a wired PC and Ooklas installable speed test app thru the RBR?
Still happen with RBS turned OFF as well?
IF you haven't changed anything then not sure if it's a Orbi issue.
- eec801Oct 29, 2023Aspirant
Yep, power off has been performed for the 1 min on both orbi and the fiber modem.
hardwired to the fiber modem with Ooklash speed test delivers 1 ms ping and >1 gig up / down. Over wifi speeds vary dramatically but the real problem is the ping latency... >200 ms at times and causing havoc on all wifi devices.
Very odd given all worked flawlessly until a week ago. Given speed at the fiber modem not sure what else it could be but the orbi network.
