Carlos84
Jan 29, 2023Aspirant
Orbi RBk852 where can I see if WIFI 6 is working?
Hello, where can I see if wifi 6 is working? in my speed port router I can see a number (6) behind the client...and where should I plugin my pc with lan, in the access point (orbi) or in my router (s...
Jan 29, 2023Guru - Experienced User
Wifi 6 doesn't normally show on your devices. its more about what speed it connects at.
None of my devices say "wifi 6"
Not sure what you mean by your "speed port" router.
Are you using more than 1 router?
Carlos84
I have a Router, Brand Telekom Speedport, then the Orbi in Access Point Mode
