Gurvy
Nov 26, 2020Aspirant
Orbi RBK852
Hi all, Have an RBK852 and an extra satellite purchased separately. Had issue with repeated drops after 4 months. Troubleshooting led to router malfunction and NG replaced with new router. Installed ...
Nov 26, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Gurvy
I would try either of those options, but I am unable to get into the Arris to make any of there changes. Optimum has made so many excuses about this that I am considering reverting to my older incoming internet (200) instead of the 1gig just to go back to the modem alone. I’ve tried to use the IP address to log in, but it brings me back to the optimum page to login. There is no configuration change I can make based on what I see.
- FURRYe38Nov 26, 2020Guru - Experienced User
Does Optimum let users buy there own modems and use them on there network?
