Dbrasee
Jan 28, 2024Follower
Orbi RBK852
Have a newer Orbi setup and we’ve been having issues with devices loosing connection to the Orbi. Recently factory reset both the Orbi and satellite and now satellite is showing completely different name from Orbi setup. Also the main Orbi is showing speeds of about 75down and 30 up but the satellite is showing 300 down and 100up. Not sure what we have going on but any help would be appreciated.
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.
