Jarvo
Sep 29, 2020Follower
Orbi RBK853 - Appropriate?
Hi All
I've recently upgraded my home broadband to 1Gbps Down/100 Mbps Up. My current BT Whole Home Wifi Mesh really isn't up to scratch in terms of speed or coverage.
I've been considering the Orbi RBK853. However I've got a couple of questions.
I'd need to run it in Bridge Mode, as I'm really impressed with the capabilities of the Firewalla Gold - Router/Firewall.
The property I'm looking to cover is circa 1500 Sq Ft for th house, and almost the same for the garden and outbuildings. But the house has 3 storeys, with the main router being located in the centre of the ground floor. It's a new build property, so no big solid walls!
Q1. I realise it's subjective, but do you anticipate that I would need the main device and one satellite, or two?
Q2. How well does the mesh handle devices moving between them? For example, I take lots of calls over WiFi Calling, and wander around the house. Prior to changing to my current mesh, I had problems where the calls would get dropped between nodes of the mesh. Keen for that not to happen again!
Thanks in advance.
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
For that size of phone, the RBR would be sufficient by itself. 1 RBS in addition max.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
WiFi Roaming is automatic and it's up to the wifi device to pick and choose where they connect too.
Thank you.
- MstrbigMaster
Jarvo wrote:Hi All
Thanks in advance.
A1. Being 3 stories, you may want the router ground floor, 1 satellite top or middle floor, 1 satellite remote building.
The RBK853 may be overkill. If you want the AX model, I have the RBK753 and it covers a 2 story large home and out building with no issues. Full WIFI throughout the home, out building, pool area and yard. It is a little less powerful than the RBK850, but also less money.
A2. There are 4 cellphones being used in the home, walking, talking, going outside, etc., and I've never experience any issues. To add to that, I'll be watching a movie or series on TV and will cast it to my phone, to go to another room and cast it to a TV seamlessly.
