skott79
Feb 27, 2020Guide
Orbi RBK853 - no way to turn off the 5Ghz wifi band? Can't get smart home devices connected.
EDIT: Just so everyone knows before responding, I've gone to the Advance tab > to Advanced > Wireless settings which is where the option would normally lie for disabling a broadcast. It's not there. ...
Feb 27, 2020Guru - Experienced User
Are you having problems with the setup phone or pad that is using the devices app to get the device installed? If so, disable the wifi radio on the phone or pad after you reduce the power on the RBR. I would move the phone or pad to a farther distance. Then turn On the wifi radio on the phone or pad, then see if it connects to the 2.4Ghz radio. Being to close to the RBR may still cause the phone or pad to connect to the 5Ghz radio even with lower power setting.
Also try disabling of the AX mode.
Are you using the same SSID name and PW from the prior router? This is recommended so most devices will migrate to the new system with out any hassle of setting them up again.
Do you still have one of the prior routers?
skott79
Feb 27, 2020Guide
To answer your questions...
- I've done those steps prior on the phone with WeMo (disable wifi on phone, turn down 5ghz signal, reconnect to wifi) but the WeMo app kept crashing. So that's on their end.
- I also keep my SSID the same as my prior router/network.
- I have not tried disabling ax. I'll try that.
- I've tried disconnecting the satellite units, moved out to my garage, checked the Orbi app under connected devices after I reconnected wifi on my phone and could see that I was on 2.4ghz. But that's when WeMo app would crash during setup of my light switch in my garage.
Anyway, if I could just disable 5ghz that would probably help alot, but judging by the posts I've seen on Reddit and other place WeMo doesn't play well with Mesh networks and they really need a firmware update and app update to solve some of the issues users encounter.
- FURRYe38Feb 27, 2020Guru - Experienced User
Try the AX mode.
It sounds like this one app is the cause. If your phone is on the 2.4Ghz radio and the devices only support 2.4Ghz, then they will not ever see 5Ghz. This app needs to be checked. Try a different phone or pad with this app to see.
Contact the Mfr of this app and let them know whats happening.
- skott79Feb 27, 2020Guide
Did everything you said, the WeMo app would either crash or it would say that it cannot connect to the WeMo dimmer. At this point I'm either gonna send the WeMo switches back or wait for a firmware update. I'm not gonna switch out the router, I just hope they update it sooner with the ability to turn off 5Ghz. Such a standard feature that is missing.
- TangmuFeb 27, 2020Star
I think 5GHz band and mesh system are unrelated. I have several devices that don't like mesh systems, and it's because they see more than one 2.4GHz radio with the same SSID, and the firmware can't handle that. These are 2.4GHz devices, so they aren't bothered by the 5GHz - they don't even receive it.
Turning off AX mode helped with some devices. Others would connect with the satellites turned off, so there was only a single broadcast of the SSID, but later they would have trouble again. Some worked after I downloaded the latest firmware.
