Raths
Nov 13, 2022Aspirant
Orbi RBK853 (AX6000) help
Does the AX6000 finally allow option 60/61 DHCP for sky. I have sky FTTP & want a mesh network but had huge trouble with other brands due to skys dhcp
Raths
I should also say i have sky FTTP 1 gigabit internet & openreach ONT
- CrimpOnNov 13, 2022Guru - Experienced User
Page 124 of the RBR850 User Manual:
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
I (personally) would purchase from a vendor with a very liberal return policy (hint: not Netgear itself)
- RathsNov 14, 2022AspirantGreat will try this its a pita the way sky has their dhcp authentication. I could use the orbis in AP mode and have the routers wifi etc off but just pricey access points at that point. So hopefully this does the trick. I shall order off amazon since the xmas returns is until jan 31st
