MixMaster
Feb 23, 2021Apprentice
Orbi RBK853 Mounting Hole Size
I have the RBK853 and the router and two satellites each have two mounting holes underneath the base. Does anyone know the thread size? I don't need to buy the entire wall mounting kit, I just need ...
- Feb 25, 2021
I reached out to a wall mount manufacturer and they said the screw is an M4 x 12mm
I hope this helps other people looking for this information.
Rick
MixMaster
Feb 24, 2021Apprentice
Does anyone have any thoughts? I actually opened a ticket with Support. Their response was that they needed to contact the appropriate department and would get back to me in 24-48 hours. So far, as a new Netgear customer I have found this community so much more knowledgeable and efficient than Netgear support.
Back to my question though...
I realize there are wall mount kits that include the Thumb (knurled) screw but I only need the thread size so I can mount it on an existing bracket. Has anyone done this?
- MixMasterFeb 25, 2021Apprentice
Rick
