MixMaster's avatar
MixMaster
Apprentice
Feb 23, 2021
Orbi RBK853 Mounting Hole Size
I have the RBK853 and the router and two satellites each have two mounting holes underneath the base. Does anyone know the thread size?  I don't need to buy the entire wall mounting kit, I just need ...
  • MixMaster's avatar
    MixMaster
    Feb 25, 2021
    I reached out to a wall mount manufacturer and they said the screw is an M4 x 12mm
    I hope this helps other people looking for this information.
    Rick
