TanujB
Aug 06, 2020Tutor
Orbi RBK853 MU-MIMO, Daisy Chain etc settings missing from admin portal (need to fix wifi drops)
Hi there, I just got the RBK853. I keep getting few specific devices kicked off wifi (an iPhone 11, iPad and recent/newer Win10 laptop).
I looked up and found some good ideas on the netgear forum but not seeing the settings such as Daisy Chain (disable), MU-MIMO (Enable) etc. I am accessing the Advanced settings by 192.168.1.1 Ux and have the latest firmware.
Appreciate any pointers. Has Netgear taken these settings off this portal?
For Orbi AX it seems NG has removed those settings. I beleieve they are automatic now. I have tested Daisy Chain and it does work when RBS are placed out in a line from the RBR.
- TanujBTutor
Thanks. I tried your suggestions from other posts of short preamble and disabling the coexistance of 20/40. I've left WMM enabled for now. I will report back if that helps.
Ok. I've not seen any problems with v32 FW loaded. Using CTS 64 as well. Though you can change this to 2347 and test it out. NG seems to feel that his value isn't recommended anymore for Orbi AX. You can revert back to 64 if you need to.
