pc74
Nov 02, 2022Aspirant
ORBI RBK853 Port Forwarding only works from External
Hi All, I tried searching but didn't find any threads with a solution. I just upgraded from Nighthawk RAX120 to ORBI RBK853 Mesh last night. I've setup port forwarding the same way as it was on th...
pc74
I've somewhat resolved my issue. So I have my subnet mask set to a /23 instead of the normal /24. My router LAN ip is set to the default 192.168.1.1 with mask 255.255.254.0. I was using the 192.168.1.x range for static ips in my network and had the dhcp giving out ips in the 192.168.0.x range. The ORBI didn't like this I guess and anything in the 192.168.0.x range was not able to use the external DNS name and port. The Nighthawk RAX120 was fine with this setup. I've moved the DHCP to the 192.168.1.x range now too, but I have left the subnet mask at 255.255.254.0 since I didn't want to change all the masks on the devices i manually setup static ip, but all seems to be working now.
I'd still like to use my split subnets for static and dhcp if any one can advise why the ORBI doesn't like this setup and how I can get it fixed and working?
Thanks in advance
- KevinLiTNov 08, 2022NETGEAR Moderator
Hello pc74,
Welcome to the NETGEAR Community!
I understand that you would like to split networks for your static and DHCP devices.
Please do the following:
Use a network of 192.168.2.1 with the subnet mask of 255.0 for your DHCP devices.
Change your current network static subnet mask address to 255.0.
You can also use the IP address 192.168.1.1 with a subnet mask of 255.128 this will give you access to 126 usable devices. Then you will be able to start your second network at 192.168.1.128 with a mask of 255.128.
Best,
Kevin
Community Team
- pc74Nov 08, 2022AspirantHi Kevin,
If I set each one to .255.0 network mask wouldn't that prevent the static ip and dhcp devices from being able to communicate with each other?
Thanks,
Peter- KevinLiTNov 09, 2022NETGEAR Moderator
Hi pc74,
Thank you for your reply!
Both solutions provided split your network into different networks. For devices to communicate they will have to be on the same network. If you would like all devices on your network to communicate you would need to use one network address. My recommendation is to reserve the IP addresses that you would like to keep static but ensure that is it on the same network.
In your case, your network subnet mask is 254.0. That gives you a network range from .0.1 -1.168. Try changing your router's IP address to 0.1 with a 254.0 subnet mask.
Best,
Kevin
Community Team
