PlanePoke
Oct 17, 2020Guide
Orbi RBK853 Satellites limited to 90Mbps
I just installed a new orbi RBK853 system: an RBR850 router, and 2 RBS 850 satellites. Both satellites are hard-wired for the backhaul directly to the router. When I do a network speed test from a ...
- Oct 19, 2020
I fixed it! Here was the problem:
When my house was wired with Cat5e, they split each cable: 4 wires for ethernet, and 4 for telephone. That will allow 100Mbps at most with 100BASE-Tx. But to get faster speeds, ALL 8 wires on the Cat5e must be used in the connectors.
Solution:
I cut the wires for the phone lines on each of the Cat5e cables I was using for the satelite backhaul (since I am not using the phone connection in the rooms where I have the satellites) and wired them on to a single connector. Then I wired them to the router in the configuration recommended by Netgear when using a switch: Wired Backhaul Now the speed I get when connected wirelessly to either of the satellites, is the same as when I am wirelessly connected to the router: The full 400Mbps download I pay for from the cable company.
I hope that this experience will be helpful to anyone else with this problem. I learned alot about the differences between Fast, and Gigabit Ethernet in this process!
Oct 18, 2020Guru - Experienced User
So the RBRs are directly wired behind the RBR or is there a switch in between by chance?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Check the link rate of your wireless device by installing wifi sweetspots on your device. Turn OFF the wifi radio on the device for 5 seconds, then back on while near the RBS. Then test.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Is Armor enabled?
