coolmoss
Oct 06, 2020Aspirant
Orbi RBK853 Second Satellite unable to work using ethernet backhaul
I am now using ethernet wired connection only for one Satellite because I can never get the other satellite to work. Setup would have been star topology (if it works). Firmware: V3.2.16.6_1.4.4...
Oct 08, 2020Guru - Experienced User
What is this "pass through"? A hole in the wall?
So when you swap locations with the RBS, the problem follows the one RBS?
coolmoss
Oct 08, 2020Aspirant
"Pass through" (they are all in the kitchen at ground floor) is basically the "data point" that allow me to plug/connect a LAN from the Router; and then in each of my room I have these connected data points that I can then plug LAN cable to my whatever devices. Each "pass through" will have a corresponding data point in each room at different floors. I could have called it data point but that's what the guys here call it.
When I swapped the RBS, the problem remained at 2nd floor (ie there is no problem with the unit)
