njweb
May 28, 2021Luminary
Orbi RBK853 (upgrading from RBK753S)- Comparison tests thread (speed and signal strength)
Well, I only recently upgraded from an RBK53 to an RBK753S (AX4200) and certainly did not expect to upgrade again so soon. However I have since gotten an internet plan speed upgrade for a nominal mon...
njweb
Update - I have the RBK853 set up already.
The Orbi app (for setup) hung near the very end of setup (sigh) when it was on 'looks like everything is working / okay (or somethong to that effect) so 'let's finish' portion. While it was hanging, I kept hitting 'wait' on the app not responding prompt (instead of hitting 'close app') for several minutes, then I hit 'close' app.
Seems it still finished getting set up luckily. No app errors, both satellites found and the internet is working fine.
Initial testing using the RBR850 to directly run Speed Test via Orbi app is 1,406.9 Mbps (my plan is 1,200 Mbps)... :)
Of course since the RBR850 only has a 2.5 Gbps WAN port and NO 2.5 Gbps LAN ports (shame!), I will not be able to (currently) get more than about 950 Mbps from any single connection (gigabig LAN limitation including overhead).
But at least I can be downloading at a full 950 Mbps via LAN port ethernet connection and still have the other 456.9 Mbps available for the rest of the network (without the need for link aggregation - LACP).
I will run some wifi tests tomorrow etc., but until the Dlink DWA-X1850 Wifi 6 AX USB network adapter comes out, I will not get close to 1 Gbps, let alone 1,407 Mbps. Even 866 Mbps theoretical maximum (which is what my current Netgear A7000 USB adapter is rated at) is going to be tough).
- njwebMay 28, 2021Luminary
I canot edit my reply anymore...
PS:
OMG I stand corrected!
I did not think it was possible, but just got 855.44 Mbps out of my Netgear A7000 (AC1900) wifi USB adapter with my RBK853 AX6000.
With my Netgear RBK753S I never got more than 585.81 Mbps (not bad either to be honest) with the same adapter in the same exact position, in fact I tested it right before switching the 'old' 753S router out for the 853.I also just tested the A7000 wifi speed (now that I have the RBK853) with another laptop on the other side of the house) and got up to 646 Mbps down vs. 475 Mbps down when I had the RBK753S.
