Ven2020
May 10, 2020Guide
Orbi RBK853 wired connection issues
I got the latest RBK853 Orbi system in the house with one router and four satellites. It came with two satellites originally and I added two additional satellites. The Wireless portion works fine but...
- May 26, 2020
Glad it's working good. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Ven2020
May 26, 2020Guide
My system seems to be working fine now, after I removed the ethernet switch from the router port. I also received a FW update, applied it and everything seems fine.
May 26, 2020Guru - Experienced User
Enjoy. :smileywink:
