packet_gnome
Aug 13, 2020Tutor
Orbi RBK853 with Elgato Key Lights
Hello all. I thought I would share this in case someone else finds it usrful. I recently installed an RBK853 (base + two satelities) in my home (switching from a prior Google WiFi system). Ever...
packet_gnome
Dec 03, 2020Tutor
I just enabled v6 in Advanced > Advanced and set it to Auto-Config. The Orbi picks up an IPv6 address on the outside interface, but leaves it unconfigured on the inside interface = no IPv6 routing (IPv6 is link-local only inside in this case). If you wanted IPv6 routing (which it sounds like you do not), I believe you'd have to enable DHCP per https://cirw.in/blog/ipv6-config.
Hope this helps. As soon as I enabled v6 in Advanced > Advanced, my Key Lights started working immediately. I later confirmed with a sniffer that they do in fact use v6.
Cheers,
Dave
grangej
Dec 20, 2021Aspirant
Dude, you saved my day. Where anywhere in the elgato docs is this?
