Tib78
Jun 03, 2021Star
Orbi RBK85X - Activation du WPA3 avec WPA2 en simultané
Bonjour, Je souhaiterais savoir si il est possible d'ajouter une option pour pouvoir activer le WPA3 avec le WPA2 en simultané sur un routeur Orbi RBK85X (comme c'est le cas sur les routeurs Nig...
Jun 03, 2021Guru - Experienced User
en anglais s'il vous plaît
Tib78
Jun 03, 2021Star
Hello, sorry i was not aware about the location on the website, i was just asking if it's possible to add an option to enable WPA3 with WPA2 simultaneously (like Nighthawk routers) ?
Currently, on my Orbi RBK852, I can only choose one mode exclusively which is not convenient if you still have legacy devices (like Nest Cam) in your network ...
Thanks for your support
- FURRYe38Jun 03, 2021Guru - Experienced User
Would be something to ask NG support about. Initially, NG has problems getting WPA2 and WPA3 to work together. Hopefully as time goes on, maybe the core stuff has been fixed enough that Orbi could be included.
- Tib78Jun 03, 2021Star
Ok i hope so because Nighthawk routers already got the option as I said (even if i guess it's not the same hardware behind)
Thanks for your reply, i will wait for an update.
