SchalkPetro
May 27, 2023Aspirant
Orbi RBK863 AX6000 Tri-Band slow
Hi everybody,
I'm a new Netgear user, and brand new to this community.
Currently, I'm an unhappy Orbi owner because the WiFi provided by my Orbi RBK AX6000 is SLOWER than what I had before using ...
SchalkPetro
Hi CrimpOn,
It's in New Zealand, so the price is in NZ$.
But I also had the heading wrong -- I went to the store to purchase a RBK853 but ended up buying the 863.
Thanks for the tip.
However, it was such a pain getting the Orbi set up -- it took me well over 4 hours, with 4 failures, before I finally had it connected to my network and working properly.
So, I'll have to wait until next weekend when I have enough time to struggle through the process again.
Everything about the Orbi so far has been painful.
Kind regards
CrimpOn
May 27, 2023Guru - Experienced User
(Duh. There are "dollars" all around the globe. "My Bad")
Wondering how this Orbi system was configured. (My only experience is with Internet Service Providers (ISPs) that use DHCP, so the Orbi will function without any configuration at all. Plug it in, and "it works". Of course, the WiFi SSID/password are what is printed on the product label, and most customers prefer to change it to exactly what the previous WiFi system was. (I have done this for over 15 years). That way, all existing devices connect automatically and do not need to be reconfigured. (And, the "bonus" is that going back is a simple matter of swapping the equipment.)
.Was this Orbi system configured using
- The Orbi 'app' ('cool', 'modern', but not offering access to any 'advanced' functions), or
- The Orbi web interface with a computer connected to the router.?
- SchalkPetroJun 01, 2023Aspirant
Hi CrimpOn,
I configured the Orbi the way the Netgear setup steps suggested -- using the Orbi App.And today, when I wanted to login to the web interface, the login page didn't accept my credentials. It didn't show ANY errors - the login page simply re-loaded with empty input fields! And after the third unsuccessful try, it said the Orbi is now disabled!
Which is (fortunately!) not entirely true, because it still worked... a good thing, because it was a workday and we were working from home!
Note: I had set up a new username & password, and saved them in my password manager, so there's no way I could have forgotten it!
But now I struggle with the decision of whether to reset it to factory settings (AARRGGHH!!!) or hope that the password reset -- which didn't work when I tried it -- finally works.
I've had ONLY pain from this Netgear system.
Perhaps I will "steal" your slogan and butcher it to "I hate my Orbi"
Kind regards,
- CrimpOnJun 01, 2023Guru - Experienced User
As you discovered, having the web password rejected three times in a row causes a "401" error and the Password Recovery screen comes up which asks for the product serial number (from the label on the bottom) and correct answers to a couple of security questions that were supposed to have been defined during the original setup. The router itself continues to function. It is only the web admin that is not accessible.
This may be part of the problem. Orbi systems feature three sets of credentials:
- The WiFi credentials, which are set at the factory to an SSID of the letters "O-R-B-I" plus a two digit number and a password consisting of two random words plus some digits, such as "harrygoblin123". Most users elect to change these credentials to something more personal. My practice is to give each new WiFi system exactly the same WiFi credentials as the system that is being replaced. This avoids having to reconfigure my WiFi devices and also means that I can "go back" to the previous system any time I want.
- The web administration credentials, which come from the factory as "admin" (and cannot be changed) and "password", which the setup process badgers customers into changing into something more secure. "admin" and this secret password are required to use the web administration.
- The credentials for my.netgear.com which are used to register products, ask for support, and access this community forum. "new username & password" would seem to imply that you are attempting to use these credentials rather than "admin" and the secret password.
If those Password Reset questions were not actually set up (and I personally configured an Orbi without doing that correctly, so I know it can be done), then there is only one method to gain access to the web admin: the dreaded Factory Reset. I hate doing this because it takes me over two hours to enter the reserved IPs for all 60 devices, set up DDNS, OpenVPN, emailing log files, etc. etc. The Orbi app does not allow any of that configuration to be done, so maybe a Factory Reset will be relatively painless in your case.
