Polemos
Jul 29, 2024Aspirant
Orbi RBK863SB AX600 Tri Mesh Wi-Fi 6 - 3 Pack
Hi I'm looking for some advice please, I need to improve my Wi-Fi in my house, single floor, but L shaped property, 23 meters wide by 35 meters long building, with each part of the L being approx. 11...
CrimpOn
Jul 29, 2024Guru - Experienced User
Page 85 of the User Manual describes how to put the router into Access Point (AP) mode:
https://www.downloads.netgear.com/files/GDC/RBK863S/RBR860_RBS860_UM_EN.pdf
I am concerned that 35 meters is too great a distance to get good coverage from one AP placed at the connection of the two wings and the other some 16-17 meters away. Do you plan to connect the two satellites to the router unit with the default WiFi connection or with Ethernet cable?
(At the very least, I would want to purchase this from a vendor with a liberal return policy.)
- PolemosJul 29, 2024Aspirant
Hi thanks for the info, yes I was a little worried about that, I'm assuming the standard working distance from base to satellite is around 9 meters from all the google searches I've done? is there anywhere that gives an expected radius of coverage for each of the base/satellites?
- CrimpOnJul 29, 2024Guru - Experienced User
I have seen internet references to -67dB being the "cut off point" between good WiFi signal and poor.
This one says -70dB
https://www.metageek.com/training/resources/wifi-signal-strength-basics/
I have found Heat Map apps to be quite useful when investigating WiFi coverage. There are a number of free apps for Android. Tablets are easier to work with because phone screens are to small. There is also Net Spot for Windows. (Maybe iOS?)
Or, you could see how far the existing WiFi coverage goes. Install the Ookla Speed Test app on anything portable (laptop, tablet, smartphone). Run it in the room with the existing WiFi router.
Record the WiFi RSSI or Link Rate and the Speed Test result, then go from one room to the next and see where performance drops too far.
WiFi transmit power is strictly regulated by the FCC (US. other countries have similar agencies)
Thanks is there anywhere i can get a graphic or measurement in sq m of expected coverage for one of these Orbi satellites? both for interconnectivity and actual Wi-Fi coverage? as i would like to map it out on plan before purchasing something that may not work effectively. cheers.
