Turbo911
Jun 26, 2023Aspirant
Orbi RBKE 963 CONNECTING TO WIFI CONTROLLED PRODUCTS
So decided to ditch my Tp Link deco WiFi system and upgrade to the rbke 963 WiFi 6 system hoping i would get better coverage with my homes WiFi, And i,m really struggling to connect my usual WiFi co...
Jun 26, 2023Guru - Experienced User
So 20ft is too close between the RBR and RBS and in between them. 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
You might turn OFF the RBS for now and just work with the RBR. Once you get things going, then turn on a RBS.
On the RBRs web page under the basic tab/wireless settings page, there should be a section towards the middle or bottom of this page that is labeled IoT network. This is were you can configure 2.4Ghz only SSID name-IoT something and give a password.
Turbo911
I have just measured and more like 25ft and the signal has to penetrate 2 feet thick stone walls and a concrete floor for the upstairs RBS, i will read up on your other recommendations,
Thanks
- FURRYe38Jun 26, 2023Guru - Experienced User
Ok that makes sense. Concrete and stone will inhibit wifi signal travel.
