changelingo
Nov 23, 2022Aspirant
Orbi RBKE 963B - slow wired connection - running out of ideas.
Fiber connection (1gbit up/down) -> Cat6 -> 963 router -> Cat6 & Cat7 cables to 2 PC's using the 2.5gbit LAN + LAN 2 Satellites working just fine, solid 6-700mbit up/down with no issues what so ...
CrimpOn
Nov 23, 2022Guru - Experienced User
Is it both the 2.5G and 1G Ethernet ports that do this?
Have you tried using two 1G ports and leaving the 2.5G port unused?
As long as the router is running the current firmware, v6.3.7.5, looks like a call to Netgear support is in order.
(If it is not on the latest firmware, they'll just tell you to update firmware, which will cost you time.)
