markw037
Mar 01, 2023Follower
orbi rbke953s connection
So i am thinking of buying the rbke953s at the moment i have other wireless AP which are connected via a ethernet port to the router.
So my questions are
A : Are they POE compatible
B : If A is yes then can i still create a mesh system by connection the satellites units to the Router/HUB provided in the 3 unit option or do i need to disconnect them and do it via the wireless connection and therefore have to buy separate a POE unit from my current unit
1 Reply
So my questions are
A : Are they POE compatible - No.
FYI:
