Tajee
Aug 03, 2022Aspirant
Orbi RBKE963 6E
So on the 6E band can I assign devices that are not 6E capable like an iPhone 13 and PS5 to use that band or will they be unable to use it at all because they are not 6E devices.
Aug 04, 2022Guru - Experienced User
You can't.
6ghz is a hardware difference. Its like to connect a 2.4ghz only device to a 5ghz network. It won't work.
The only devices that can connect to 6ghz are those that have the built in capability
