ih87's avatar
ih87
Orbi RBKE963 daisy chain question
Hello All!   Recently purchased a 3pack Orbi 960 with RBRE960 router and two RBSE satellites.  I'm wondering if there is a way to enable wireless daisy chain or is it auto negotiated?  I ask becaus...
  • ih87's avatar
    ih87
    Feb 02, 2023
    Hi plemans , FURRYe38
    Thank you both for your comments! I played some more with the physical layout and it appears that wireless daisy chain clearly works based on the network map when logged into the router admin!
    Thanks again,
    Best,
    ih
