ih87
Feb 02, 2023Aspirant
Orbi RBKE963 daisy chain question
Hello All! Recently purchased a 3pack Orbi 960 with RBRE960 router and two RBSE satellites. I'm wondering if there is a way to enable wireless daisy chain or is it auto negotiated? I ask becaus...
Feb 02, 2023Guru - Experienced User
It'll auto negotiate. And it tends to work pretty well.
Are you having any issues with it?
- ih87Feb 02, 2023AspirantHi plemans , FURRYe38
Thank you both for your comments! I played some more with the physical layout and it appears that wireless daisy chain clearly works based on the network map when logged into the router admin!
Thanks again,
Best,
ih- FURRYe38Feb 02, 2023Guru - Experienced User
Kewl, thanks for letting us know. Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- ih87Feb 02, 2023Aspirant
Thanks again FURRYe38 !
One more quick question: There is a legacy, iPhone 6 in the household which is unable to connect to the new (Orbi) wifi? Does this have anything to do with the fact that there is only one SSID broadcast (for 2.4, 5, and 6GHz) and the router negotiates which device goes where? If so how do I remedy this? Or maybe I'm missing something on the client side?
Thanks again for all your help!!
Best,
ih
