ih87
Feb 02, 2023Aspirant
Orbi RBKE963 daisy chain question
Hello All! Recently purchased a 3pack Orbi 960 with RBRE960 router and two RBSE satellites. I'm wondering if there is a way to enable wireless daisy chain or is it auto negotiated? I ask becaus...
Feb 02, 2023Guru - Experienced User
Last system that you could disable or enable DC was Orbi 20 thru 50 series. All Orbi AX systems are auto now.
ih87
Thanks FURRYe38 !
In parallel I got in touch with tech support and they told me daisy chain topology would only work over wired and wireless is a few months away, potentially with a firmware release… this left me thoroughly confused. Perhaps the misunderstood my question?
Appreciate comments!
Kind Regards,
ih
Kind Regards,
ih
