ih87
Feb 02, 2023Aspirant
Orbi RBKE963 daisy chain question
Hello All! Recently purchased a 3pack Orbi 960 with RBRE960 router and two RBSE satellites. I'm wondering if there is a way to enable wireless daisy chain or is it auto negotiated? I ask becaus...
HaroldCarl
Feb 10, 2023Tutor
As a curious related question. Is anyone aware if the RBKE960 Router can simultaneously use the 2.5gbps LAN port for backhaul, and use (2) or more 1gpbs ports for LAG regarding the LAN?
CrimpOn
Feb 10, 2023Guru - Experienced User
The RBRE960 User Manual mentions the word "aggregation" only in terms of the WAN interface.
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
This is only a guess, but perhaps a suitable solution would be to find a 2.5GB switch that supports port aggregation.
One port to the router 2.5GB port and two ports to whatever device that supports aggregation over gigabit ports (NAS?)
