MrJamison
Aug 01, 2023Aspirant
Orbi RBKE963 router solid white LED for over a week, but working fine.
Title says it all. I have had this for a while now and it is working as expected. The other day, I went to the closet and noticed that the router had a solid white led. Not flashing, but solid. It ha...
Aug 01, 2023Guru - Experienced User
Nope.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- MrJamisonAug 01, 2023Aspirant
Thanks for the reply FURRYe38.
- I am using 2.5GB Frontier Fiber. The ONT and Moca are the same as the day they were installed (not at home atm to check model), just the Orbi LED behavior is new.
- No new equipment and the cables are Cat6A from Eaton.
- Router is RBRE960 running FW v6.3.7.10. FW check reveals no new FW available.
- FURRYe38Aug 01, 2023Guru - Experienced User
Is the ONT and MoCA HW new?
You mention the front LED as new behavior. Had the front LED been OFF before?
The MOCA and ONT have been installed for about 7 months. The front LED was always off before if memory serves. It would be solid or flashing white after booting up or a manual sync, but then go off. Staying on and white 24/7 is new. I do not look at the router very often, because it is in a guest room. I may only see it once or twice a month. When I switched to Frontier, I spent some time in that closet organizing and I am certain that LED was not static before.
In the end, everything is working as expected, so maybe I just ignore it and see if it ever turns off after the next FW update. I was hoping someone else had the same behavior and could explain it.
