Arnodoc
Feb 23, 2024Tutor
Orbi Rbr 350 satellite magenta but working
One of My rbs 350 satellite is magenta but is still connected to others satellites since those one stay green and get the wifi from the magenta one. 3 on the four satellites are detected on the app ...
Arnodoc
Feb 23, 2024Tutor
Thanks
The rbr 350 ´ firmware version is
4.4.1.29_3.10.80
I have a quite big house 250m2, but I have 4 satellites, so I don’t think the distance between satellites is a pb (less than 30 feet)
This happened after the satellite was unplugged (all the others where still plugged) unfortunately when I was on vacation and which became magenta when I came back and plugged it again (I rebooted all parts but still magenta)
Sorry I can’t show you the mapping on the app ( impossible to browse the screenshot) you should better understand
4.4.1.29_3.10.80
Feb 23, 2024Guru - Experienced User
Try turning OFF the other RBS and see if this one RBS will connect while near or in same room as the RBR.
IF your placement of the RBS is less than 30 feet, then this could be a problem. 30 feet or more is recommended distance between the RBR, RBS and each other to start.
So a 4000-5000 sq foot home?
- ArnodocFeb 24, 2024Tutor
See the screenshot
i have 4 RBS satellites with RBR 350 orbi
one does not seem to be connected but is connected to the others... (mapping pict)
i have the latest firmware, and tried to reset already
3 of 4 satellites are detected
do i reset from factory reset ?
thanks
- FURRYe38Feb 24, 2024Guru - Experienced User
