Jiri1
Sep 23, 2021Follower
Orbi RBR 750 - PC disconnecting if WPA2 security method is used
Hi I am having problems with my RBR 750 (plus two satellites) as my PC keeps disconnecting every minute or so if WPA2 security method is used. All other devices work fine. If WPA3 is used instead, t...
Sep 23, 2021Guru - Experienced User
Its just the 1 device disconnecting?
What firmware is on the router?
What wireless card is in the pc?
What driver version is on the PC?
