Pablo1601
Aug 11, 2020Aspirant
Orbi RBR 750 does not connect to Epson Workforce 545 Printer
I've made several attempts to connect my Epson Workforce 545 to my Orbi network but cannot connect. Is there a way I can connect?
- Nov 14, 2020
Thanks for the advice Mikey94025.
.My Epson Artisan 837 connected right up (Orbi RBR 750 ) once I followed this step:
- Set CTS/RTS threshold for 2.4Ghz to 2347 in Advanced... Advanced... Wireless Settings.
Best regards,
Steve1Ski
CrimpOn
Aug 11, 2020Guru - Experienced User
It is sort of awkward now that people are buying the new "AX" Orbi's to point out that Netgear has a community forum specifically for those products: https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Searching for "orbi forum" brings you here, where we all have the "original Orbi". Besides the obvious envy, we have no experience with the AX products. You will probably get much better advice by posting in that forum.
Because connecting printers should be very similar no matter which Orbi is involved, can you describe at what point in the process "things break down?" Looking at "Connection Options" in the installation guide, where does it fail?
