Pablo1601
Aug 11, 2020Aspirant
Orbi RBR 750 does not connect to Epson Workforce 545 Printer
I've made several attempts to connect my Epson Workforce 545 to my Orbi network but cannot connect. Is there a way I can connect?
- Nov 14, 2020
Thanks for the advice Mikey94025.
.My Epson Artisan 837 connected right up (Orbi RBR 750 ) once I followed this step:
- Set CTS/RTS threshold for 2.4Ghz to 2347 in Advanced... Advanced... Wireless Settings.
Best regards,
Steve1Ski
Aug 14, 2020Guru - Experienced User
Any progress on this?
Pablo1601 wrote:I've made several attempts to connect my Epson Workforce 545 to my Orbi network but cannot connect. Is there a way I can connect?
ak45
Aug 29, 2020Aspirant
I'm having same problem, RBR750 orbi wifi is not connecting to Epson Workforce 635 Printer. I have tried changing the channel for 2.4 Ghz from Auto to 11 and 6, but still printer is not connecting to wifi. Tried WPS push button method as well as manual, nothing is working. Please let me know if anyone knows hor to fix this issue. Printer was working fine on old router.
- FURRYe38Aug 29, 2020Guru - Experienced User
Try disabling AX mode on 2.4Ghz.
Try setting CTS values from 64 to 2347, Under Advanced Tab/Advanced Settings/Wireless Settings...
ak45 wrote:I'm having same problem, RBR750 orbi wifi is not connecting to Epson Workforce 635 Printer. I have tried changing the channel for 2.4 Ghz from Auto to 11 and 6, but still printer is not connecting to wifi. Tried WPS push button method as well as manual, nothing is working. Please let me know if anyone knows hor to fix this issue. Printer was working fine on old router.
- Mikey94025Aug 29, 2020Hero
Try each of these (in order):
- Turn of AX mode for 2.4Ghz in Advanced... Setup... Wireless Setup.
- Try changing your wireless security to "WPA-PSK [TKIP] + WPA2-PSK [AES]" in Advanced... Setup... Wireless Setup.
- If this works, this is not an ideal workaround because you are degrading the security of all your wireless devices just to support a 10-year-old wireless printer. Now may be a good time to upgrade your old printer to one that supports the latest and most secure wireless protocols.
- Do you recall what security setting your old router was using? It may not have been WPA2-AES but instead "WPA2-PSK (TKIP)".
- Pablo1601Aug 30, 2020Aspirant
All,
Thanks for the recommendations and posts regarding my problem with Epson Workforce 545. I initially had a conflict with my AT&T modem and ORBI 750 router that precluded my printer from printing and scanning. The conflict occurred because my printer was using an AT&T generated address provided by the modem. I corrected the problem by resetting my printer and applying an ORBI generated address. Thanks much.
- FURRYe38Aug 30, 2020Guru - Experienced User
Glald you got it working.
Regarding modems with built in routers, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopPlease mark your thread as solved so others will know.
Enjoy. :smileywink:
Pablo1601 wrote:All,
- ak45Aug 30, 2020Aspirant
Thanks a lot, it worked with the changes you recomended!
Please mark your thread as solved so others will know. Enjoy. :smileywink:
- Steve1SkiNov 14, 2020Initiate
Best regards,
Steve1Ski
- FURRYe38Nov 14, 2020Guru - Experienced User
Glad it worked. Enjoy. :smileywink:
Steve1Ski wrote:Thanks for the advice Mikey94025.
Best regards,
Steve1Ski
