RSMV
Apr 25, 2022Tutor
Orbi RBR 750 is very unstable
Have an RBR 750 with 3 satellites and a few things hardwired into the ports. It's wired into the Comcast cable modem. The 750 frequently (~5X week) goes magenta. There is still internet at the Cab...
Apr 25, 2022Guru - Experienced User
Which unit shows PINK in front? RBR or RBS or do all unit show PINK?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- RSMVApr 25, 2022Tutor
Current firmware is 4.6.7.13
The ISPs modem is a generic xFinity modem. Doesn't have a MFR or model# that is identifiable from label on the bottom
The RBR shows pink.
Yes as to the power cycle on the modem and RBR, tho I don't know any way to "turn off" either device other than unplugging them.
thanks
- FURRYe38Apr 25, 2022Guru - Experienced User
There a picture of this modem? Need to get more info on this if possible
If the RBR shows pink, only a few items that can cause this, bad cable between the modem and router, loss of connection with the modem, or modem isn't giving good ethernet services to the modem or modem is having problems.
What CAT# LAN cable is being used between the modem and router?
Thanks.
Pic of Comcast modem attached. It goes to the Netgear switch (pic also attache if I've enough room). It's Cat 5 from the Netgear switch to the RBR.
The wiring has been the same for a few years. Not clear why there would be deterioration there. Is it the case if the Comcast modem is failing in its provision of ethernet that IT"S internet access via wifi would remain undiminished? When the Orbi goes pink, I can still use the Comcast wifi and connect to the internet. (The signal is too weak for most of the house, which is why I set up the Orbi network).
