Gmurakami
Dec 31, 2020Tutor
Orbi RBR 750 issues with Netgear AC1750 cable modem
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgrad...
- Dec 31, 2020
Enjoy. Please mark your thread and solved so others will know. Enjoy. :smileywink:
Happy New Year.
Mstrbig
Dec 31, 2020Master
Gmurakami wrote:
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgraded, but I can't access router login site. Considering all devices are netgear I cannot figure out why not working. Considering returning cable modem for Arris modem. Please help with any advice.
Thanks in advance for any help
Why do you want to just eliminate the Netgear AC 1750 router all together and just connect the Orbi router to the Spectrum modem, and set the Orbi router in router mode?
Or are you referring to a different Netgear router?
Gmurakami
Dec 31, 2020Tutor
To clarify, I replaced Spectrum modem with the Netgear cable modem. The Orbi router is connected to the Netgear modem. The Spectrum modem was slow plus I wanted to get away from monthly fees. My house is older and made of cement brick. I need the Orbi router and satellies to extend the coverage
- FURRYe38Dec 31, 2020Guru - Experienced User
Need to bridge or set modem only mode on the NG cable modem if this is a modem with built in router and wifi.
What C series model is the NG modem?
Gmurakami wrote:To clarify, I replaced Spectrum modem with the Netgear cable modem. The Orbi router is connected to the Netgear modem. The Spectrum modem was slow plus I wanted to get away from monthly fees. My house is older and made of cement brick. I need the Orbi router and satellies to extend the coverage
- MstrbigDec 31, 2020Master
Then you gave the wrong model of the netgear, as your first post referred to a specific model AC-1750
AC1750 WiFi Router (netgear.com)
