Gmurakami
Dec 31, 2020Tutor
Orbi RBR 750 issues with Netgear AC1750 cable modem
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgrad...
- Dec 31, 2020
Enjoy. Please mark your thread and solved so others will know. Enjoy. :smileywink:
Happy New Year.
Mstrbig
Dec 31, 2020Master
Gmurakami wrote:
i recently switched out Spectrum modem with Netgear AC 1750 and have Orbi connected as older cement brick house. Now Orbi speed test won't work and Netgear keeps telling me firmware needs to be upgraded, but I can't access router login site. Considering all devices are netgear I cannot figure out why not working. Considering returning cable modem for Arris modem. Please help with any advice.
Thanks in advance for any help
Why do you want to just eliminate the Netgear AC 1750 router all together and just connect the Orbi router to the Spectrum modem, and set the Orbi router in router mode?
Or are you referring to a different Netgear router?
Dec 31, 2020Guru - Experienced User
I think he's referencing the NG cable modem which is probably a C series gatway router modem already. So if this is the case, then they just need to configure the modem for modem only mode. Which would be the first step in solving problems.
- GmurakamiDec 31, 2020Tutor
C6300v2 is tne modem router. I so appreciate everyone trying to help
- FURRYe38Dec 31, 2020Guru - Experienced User
Go into the modems configuration and under Advanced tab/Advanced settings should be Mode or Router mode? Options maybe Yes or No. Select No and apply the setting. This will change the configuration of the modem to Modem only mode. When this happens I would power OFF the RBR for 30 seconds then power back ON. RBR should connect and show GOOD under Internet status on the RBRs web page.
FURRYe38 your advice was awesome! I did what you recommended and so far so good. Your instructions were easy to follow and I'm hoping fix works. Not the most tech saavy so everyone's advice and support was helpful.
Thanks for the help and hope everyone has a safe New Years! Gail
