panthorpan
May 15, 2022Guide
ORBI (RBR 750) Router refuses to sync with satellite
My Orbi router stopped connecting to the satellites after the subscription to NETGEAR Armor ran out. Please let me know how to fix this issue? I have re-set the router and satellite to factory settin...
panthorpan
May 15, 2022Guide
ChristineT Blanca_O Thank you, please keep me posted. Currently I do not have a way to look at what firmware version the satellites are as they don't appear on the app or via orbilogin.com. My router is on the version V4.6.5.14_2.0.54.
May 16, 2022Guru - Experienced User
What happens if you connect the RBS via ethernet cable to the back of the RBR?
- panthorpanMay 16, 2022Guide
If I connect them via an ethernet cable the lights turn blue but the satellites wont sync.
- FURRYe38May 16, 2022Guru - Experienced User
Do you see a IP address listed for the RBS at all on the RBRs web page when the RBS is ethernet connected?
No I do not see any
