AliceandScott
May 09, 2022Aspirant
Orbi RBR 750 slow speed
Hi everyone, apologies for asking the same question as everyone else. However, I had an IT person come to the house and he couldn't solve this problem either. Orbi RBR 750 Computer: 2019 Mac...
- May 09, 2022
If your not seeing better speeds after the reset, RBR could be faulty. Return and find another.
AliceandScott
Ok. Tried the factory reset. Manually set channels.
No change.
Do you think the unit is defective?
May 09, 2022Guru - Experienced User
- AliceandScottMay 09, 2022Aspirant
FURRYe38 Grateful for your advice.. Will buy another unit. Thank you!
- FURRYe38May 09, 2022Guru - Experienced User
đ
