MJR1967
Dec 07, 2022Aspirant
Orbi RBR 750 sporadic signal and devise acceptance
Greetings to all,
We own a 2 year old Orbi 750 with 2 satellites. It is used as a router, the modem is from xfinity and runs at 900 odd Mbps as per the orbi app. Lately, orbi has become sporadic, m...
- Dec 09, 2022
Glad you got it working. BE sure to check out the DMZ on the modem if it's in router mode and if the Orbi is in router mode as well. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
michaelkenward
Dec 08, 2022Guru - Experienced User
What is that xfinity modem?
What firmware version do you have on the Orbi device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
