MJR1967
Dec 07, 2022Aspirant
Orbi RBR 750 sporadic signal and devise acceptance
Greetings to all,
We own a 2 year old Orbi 750 with 2 satellites. It is used as a router, the modem is from xfinity and runs at 900 odd Mbps as per the orbi app. Lately, orbi has become sporadic, m...
- Dec 09, 2022
Glad you got it working. BE sure to check out the DMZ on the modem if it's in router mode and if the Orbi is in router mode as well. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Dec 08, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
MJR1967 wrote:
Greetings to all,
We own a 2 year old Orbi 750 with 2 satellites. It is used as a router, the modem is from xfinity and runs at 900 odd Mbps as per the orbi app. Lately, orbi has become sporadic, my phone can connect to orbi but my iPad can’t. Well, it will for 10 secs and then say, no connection. It does the same to other family members. The modem works fine-our main connection point now- but orbi just wont. It decided to stop working for some reason just before midday CA times yesterday. I have done plenty of reboots, of both the orbi system and the modem. Xfinity modem always works, orbi does not.
We never had parental control on, all the kids are grown ups but on the parental control site it says “all profiles paused” even though the program has expired.
we are at a loss, is it time, after 2 years, to through orbi 750 in the bin or are we doing something wrong. Any help is most appreciated. As I’ve said, done all the reboots etc, only thing left is a factor reset which i am loathed to do as it means resetting Sonos etc which is a pain in the bum.
Thanks in advance for any suggestions, help before we send orbi to the recycling heaven.
MJR1967
Dec 08, 2022Aspirant
Many thanks Furry for your reply. We are due some rain this afternoon so I will go through the suggested protocol then.
I will report back with any results. If this fails i am inclined to ditch the system and use some Xfinity/Comcast extenders instead. More anon.
- FURRYe38Dec 08, 2022Guru - Experienced User
What brand and model is the ISP modem?
- MJR1967Dec 08, 2022Aspirant
Greetings, it is the modem from Xfinity/Comcast we are on their 1200 mbps plan. No brand name on it but it does work, we are using this for the moment.
I will do a full reset and hope for the best,
many thanks again, M
There should be a model# on a stick under or behind the modem...
