MJR1967
Dec 07, 2022Aspirant
Orbi RBR 750 sporadic signal and devise acceptance
Greetings to all,
We own a 2 year old Orbi 750 with 2 satellites. It is used as a router, the modem is from xfinity and runs at 900 odd Mbps as per the orbi app. Lately, orbi has become sporadic, m...
- Dec 09, 2022
Glad you got it working. BE sure to check out the DMZ on the modem if it's in router mode and if the Orbi is in router mode as well. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
MJR1967
Dec 08, 2022Aspirant
Many thanks Furry for your reply. We are due some rain this afternoon so I will go through the suggested protocol then.
I will report back with any results. If this fails i am inclined to ditch the system and use some Xfinity/Comcast extenders instead. More anon.
Dec 08, 2022Guru - Experienced User
What brand and model is the ISP modem?
- MJR1967Dec 08, 2022Aspirant
Greetings, it is the modem from Xfinity/Comcast we are on their 1200 mbps plan. No brand name on it but it does work, we are using this for the moment.
I will do a full reset and hope for the best,
many thanks again, M
